Upman h-e-l-p
ndswan
Ludington, Mi
I have a BCD996T which i have sucessfully upgraded to the 1.04.12 software, and have the v2.0.0.7 ready to install v3.02.00. However, when I try to register it, I get the message that I allready have. Then, I ask to have the password e-mailed to me and that is where I am. No answer, No ESN (where would I find this?) no checksum (where would I find this?) and no password or log in name. THEREFORE, not able to install v.3.02.00.
Some of the pages refered to are no longer, or come up with those words from your website.
H E L P !!!!!
(This is embearsing, as I am a dealer and suppose to know this stuff to help my customers!)
Nick Swan
Nicks Radio
sjlamb
Sarasota County, FL
You should be embarrased. As a dealer, you should know that if you:
Press "MENU"
Select "SETTINGS"
Scroll to and Select "See Scanner Info"
Select "Firmware Version"
You will find the unit's ESN and Check Sum #s. Beneath the batteries, you will find the ser. #.
It also sounds as if this radio may have been previously registered by someone.
garys
Press "MENU"
Select "SETTINGS"
The 996T has batteries?
garys
My error... I had 396T on the brain. S/N then, as I'm sure you're aware, is on the rear panel. The rest of my original response still applies.
I know, I was just having a bit of fun.
