URL Link Problem
#1
All links to Starnet Motorola are down (http://www.radioreference.com/apps/db/?sid=38)
Links to other systems work.
This is the message I receive:
Page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Please try the following:
If you typed the page address in the Address bar, make sure that it is spelled correctly.
Open the www.radioreference.com home page, and then look for links to the information you want.
Click the Back button to try another link.
Problem: Unknown Error -1.
loumaag
Silent Key - Aug 2014
Katy, TX
#2
I moved your post, it really had nothing to do with the map problem.
In any case, I am not seeing this, are you still having the problem?
#3
It was the closest similar topic I could find. Someone, may have seen my post and fixed the problem. It is working now.
Thanx.
