usb converter
patkitch
PNW
#2
What operating system do you have on your computer? Did your purchase the usb converter from Uniden? You want to make sure the USB-1 cable uses the Prolific PL2303 chipset. I just purchased mine and follow the instructions and had only one issue and that was, I did not unplug my scanner from the power and plug it back in holding FUNC and 6. Once I did that it installed the drivers.
The site below has the instructions you need. Sorry if this is something you are aware of.
USB-1Drivers < UnidenMan4 < TWiki
garys
Eastern MA
#3
I've had very good luck with USB converters using the FTDI chipset up through Windows 8. I haven't tried it with Windows 10, so I don't know if they still work.
You don't need the USB-1 from Uniden specifically. The advantage of that cable is that it's a one piece cable while the other converter cables terminate in a 9 pin serial connector. The disadvantage is that they were, last time I checked, fairly expensive.
