I am trying to locate a right angle adaptor for the USB mini cable that plugs into the side of my WS-1088. Can anyone advise which adaptor I should order and where it may be ordered from? Thanks in advance for your help.
jimg
jimg
I've been looking for something like that too. Unfortunately all I could find was replacement cables with angled mini-b tips. And the angles put the cable either down or up when connected to a Whistler scanner...I wanted one to make it go towards the rear of the scanner. I use a couple of GRE800-type units in deep phone holders as mobiles and I'd like to get the cable tucked in a little better. That adapter does exactly the same thing as the cables I found do.Amazon
OEM SKN6182a Motorola mini-USB EMU Angle Port Adapter
(111009099454)
They have right and left angle so be sure to order the one you want. They look identical except for right or left.
You need an Up or Down angle cable.I've been looking for something like that too. Unfortunately all I could find was replacement cables with angled mini-b tips. And the angles put the cable either down or up when connected to a Whistler scanner...I wanted one to make it go towards the rear of the scanner. I use a couple of GRE800-type units in deep phone holders as mobiles and I'd like to get the cable tucked in a little better. That adapter does exactly the same thing as the cables I found do.
Looks like we were both posting at the same time.You need an Up or Down angle cable.
Here's an Amazon link that allows you to select up or down and I think, length.
Yep!Looks like we were both posting at the same time.
I looked at those and almost clicked as the 1.5' length would be perfect to reach the lighter plug/power port/whatever adapters from where they're both mounted (car and pickup)...and then I saw the price.Yep!
Watch the price though. I noticed what I linked was crazy high. I've bought left/right and up/down for about $5 per cable somewhere on Amazon or eBay before.
Ha, I missed the link you had added!I looked at those and almost clicked as the 1.5' length would be perfect to reach the lighter plug/power port/whatever adapters from where they're both mounted (car and pickup)...and then I saw the price.I'll stick with what I found above, even having to throw away the incorrect ones it's still a lot cheaper.
Wrong angle but thanks for the effort.Amazon.com: Motorola USB EMU Angle Port Adapter Skn6182a for Razr V3c V3 V3x V3i Pebl
Buy Motorola USB EMU Angle Port Adapter Skn6182a for Razr V3c V3 V3x V3i Pebl: Accessories - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
