Hi Folks.
I'm playing around a lot with Zello right now, and loving it as a streaming platform as it fits my needs really well.
Evidently I can run up to 8 instances of Zello at once. This is working well when using SDRs, but for aviation feeds I am using some old Pro-2006s among other radios.
Does anyone know of a USB audio device that can capture 4 to 8 simultaneous inputs that can be piped to individual Virtual Audio Cables?
e.g.
Radio 1 - Clearance -> USB Audio Input 1 -> VAC 1 -> Zello channel 1
Radio 2 - Ground -> USB Audio Input 2 -> VAC 2 -> Zello channel 2
Radio 3 - Tower -> USB Audio Input 3 -> VAC 3 -> Zello channel 3
The goal is for each feed to have its own Zello channel, rather than just having a scanner scan the channels to 1 feed.
Feeds from my scanners would typically be on standard 3.5mm aux cables.
Hardware advice most welcome!
e.g.
