USB to serial adapter info
I'm wanting to get a USB to serial adapter for programming the motorola radios we have that didn't come with a USB programming cable. I'd rather just go buy the same adapter that is already working for someone here. The radio's I'll be programming are the HT750's and 1250's, CDM mobiles, and P1225's.
So if someone could give me the make and model of one that is working for them now, I'd appreciate it.
chrismol1
P25 TruCking!
one of the many usb to serial adapters motorola recommended is the IOGEAR GUC232A. I use it and have never had any problems
K9WG
Greenfield, Indiana USA
I might add, the Sabrent (and probably most) USB/Serial devices assign a virtual COM port. Some of these can have a high port number so make sure your application will support these. Example, my laptop assigns ports COM-5 through COM-8.
davidgcet
i have a standard old Belkin USB/Serial adapter and never had an issue with it on everything from Windows ME to Windows 7 and every type of CPS for US products.
if your machine assigns a high port number, you should be able to go in the device manager and change it. i always set mine to com 1, never had an issue that way, because sometimes com 5+ is squirrelly with older CPS versions.
Av8tor56
Roswell, NM
We used some USB adapters to program XTL 5000s and found that we had to slow down the speeds to allow the computer to talk to the radio. The XTLs at least were very picky on com speeds and in some cases we couldn't communicate at all. We were using 3 XP machines to program 1500 radios. The biggest problem we had was with the flash upgrades. Fortunately, we had one computer with RS 232.
WayneH
Forums Veteran
Super Moderator
Your master site
I've used and still use the IOGear GUG232A. It's always worked well enough to get the job done but anything that is very error sensitive may have issues.
K8TEK
Banned
Ohio
Nothing will beat a real RS232 port. I bought a socket pcmcia rs232 port and I use it for everything requiring a serial port. The computer I use has a serial port built in, but it is a dell and for some reason, dell's serial ports don't work correctly.
Those of you using Windows 7 64bit for programming radios, get another laptop. They are cheap, you should be able to get a Windows XP laptop for under $100 on eBay or a pawn shop. I value my radios enough to use proper equipment to program them.
