USB to serial cable NX-820
chrishoerner
KC3KSJ
Frederica, Delaware
Hi all
Anyone know of a known working usb to db-15 serial cable for pulling gps info from a base station? I have some db25 to usbs working on an nx 800 & an nx 5800 but every db 15 to usb cable I see on amazon or ebay says its vga. I bought a db9 to usb thinking the port on the 820 was a 9 pin but its 15 pin.
Thanks!
ramal121
Lots and lots of watts
Calif Whine Country
There is no specific cable DB-15 to USB cable for this model. If you need to pull data out for GPS you'll have to make your own adaptor cable.
You can do this one of two ways. First, you can make a DB-15 to RJ-45 adaptor cable and then use the KPG-46 program cable to connect to your computer USB port. Second, you can modify the radio to output RS-232 serial levels. You would build a DB-15 to DB-9 adaptor cable and then you could hook that to the serial to USB cable of your choice.
Either way there is no off the shelf solution for this.
