My apologies if this has already been answered; I've been trying hard to keep up with all the SDS100 threads but I'm sure I could have missed it.
I know that Upman told us that the microUSB port can be used to power the SDS100, but not charge the battery. My question is, can you power it using the microUSB and still connect it to a PC using the miniUSB connector? I'm pretty certain that the authors of ARC536PRO and ProScan are working on virtual displays, but will those only work if you have a USB port on your PC that will put out 2.4 amps (or whatever the SDS100 is drawing)? Aren't PC USB ports usually limited to 1 Amp?
