I live on a 14th floor apartment with no roof access. So my antenna options are limited. My PL-310ET radio works well, with no extraneous noise at the window. I picked up a cheap Diamond FH205 telescopic antenna from a local store. It is rated for 144Mhz.
The antenna is clamped against the window, and fed to my radio with a shielded coaxial cable. This allows me to listen at the desk, and not by the window.
The problem I have is that the antenna picks up a lot more noise compared to the radio's whip on "sub-optimal" day/night bands. Example: 31m band in the day is noisier with the FH205 antenna, and 22m - 19m is noisier at night. 31m band at night and 22-19m band in the day is excellent.
I confirmed it wasn't the coaxial because the radio is dead quiet when the antenna is disconnected. So I'm curious:
1. Is the noise caused an antenna not rated for below 30Mhz?
2. Are there special filters for the built-in whip that isn't present on antenna inputs?
3. Do I need some kind of balun/choke transformer between the antenna and coaxial cable?
I'm pretty new to shortwave listening so any advice will be appreciated.
