Using a TNC to decode
Radiorick
How many of you gents use one in your shack? I thinking about getting on to tool around in HF. Looking on ebay it may just be cheaper to get a older TNC rather than a lvl4 FSK decoder. Any ideas?
key2_altfire
I've had my eye on the TNC-X, it's PIC-based and very affordable. Official site is tnc-x.com
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The problem with these old TNCs is that many of them have not been updated for newer modes in years (The M7000 is a classic example). Even the venerable PK232 now has, in their newer versions, a soundcard input, probably in recognition of the many new modes that have come on the air of late.
You're far better off getting a soundcard driven software package than a dedicated TNC. However, for very specific apps such as FAX decoding, a TNC might do a better job due to the additional filtering some of them have.
It does depend on what you are trying to hear. For example, marine stuff can generally be copied with something along the lines of SeaTTY; for all the new ALE stuff that's out there, and coming out, PC-ALE (which is freeware) is a very inexpensive way to get your foot in the door without a lot of cost. You can later step up to software like SkySweeper (which in it's basic form, is still quite powerful, and not that expensive..).
Mike Chace-Ortiz's website has numerous links for just such software - the link for his site is in the Utility Monitoring wiki. Of course, this assumes you have a good desktop radio - you can get by with portables, but only to a point. Weaker stations, or those with interference, will quickly show the portable's limitations. Some of the better PC driven radios (like the RX320 from TenTec) are also quite good for digital decoding.
73s Mike
Radiorick
I'm using PDW as on now off the PCR-1000 and have had success. I'll be checking out that site.
n9mxq
Belvidere IL
I you want a nice multimode decoder, try Ham Radio Deluxe Plug your radio into the sound card, open the DM780 program that comes with HRD... It decodes several modes.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
While I agree programs like DM780 and MixW are very good, they're generally oriented toward ham ops - stations outside the ham bands (not necessarily MARS related), don't use things like PSK31, Clover or other modes like that - and that's an issue, particularly for newcomers. They think that they can just tune in with any mode and expect it to work. Digital decoding simply doesn't work that way. All they get is gibberish, and quickly lose interest.
I highly recommend folks that are interested in Digital HF DXing join groups like the Utility DXers Forum (Yahoo) - there you can get a very good idea of what modes are being used, and the equipment or software used for decoding.
73s Mike
kb2vxa
Banned
Point Pleasant Beach, N.J.
Why bother with hardware when everything is software driven? Digital radio is as easy as getting on the internet these days, your sound card is your modem.
jparks29
John McClane
Nakatomi Plaza
I agree...
Check out AGWPE.
k8mcn
Old Monroe,MO
totally correct!!!!!!!! You are only limited by what software you use and how much your sound card can decode. Listen and listen and hopefully find lots to decode. most software tells you how to set it up--one mistake i was making, you can run too much volume into the programs---it will tell you that usually...
The reason you need the interfaces (since most people have computers these days) TNC, Rigblaster,etc, is if you want to send (broadcast) in a certain mode, and you must be licensed to legally do that.......
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
What you all have written is right on the money, but it misses the point - all these neat packages are really geared for ham usage. There are many other modes that aren't common - or even used - by hams on HF, and some of these (like Link11) cannot be decoded.
The only software (within reach of the average listener, anyway) that addresses these modes is SkySweeper. There are several more expensive packages (Hoka Code 300 for example) that cover even more modes and have more technical capabilities. Something like that would undoubtedly overwhelm someone who is new to the hobby. This is why research, and more specifically learning about what is being heard and read on reflectors such as the Utility DXers Forum, is absolutely critical. It will at least slow down the frustration factor.
73s Mike
n8emr
A TNC is pretty much useless on HF. If you want to do digital decoding you would be better off with one of the many sound card software packages. A TNC will give you 300baud packet and little more.
Viper43
Skysweeper no longer supported sine June 2009
73s Mike
Not tying to start anything Mike but why suggest software such as Skysweeper thats no longer supported by the company that wrote it? According to the Scancat site (who isn't the company that wrote it or supported it) it hasn't been supported since June of 2009 and it would seem foolish, if not irresponsible to send new people to a program with no support, especialy since there would be no guarantee they could even register the software or get user support. And it would seem difficult at best to "step up to Skysweeper" with no support. Just curious.
V
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Viper, take a look at the date of that message. You are correct that SkySweeper is no longer supported, but it still was almost 2 1/2 years ago. Homer Simpson moment, methinks
73 Mike
k8krh
I dont use a tnc ... just to decode use multipsk..it is free...and I never use a tnc..just a cable from the radio to the pc and use the pc soundcard..works good for me for the past number of years for any digital modes..I also use it to transmit.
DOCTOR
K
kb0nly
Guest
MixW while geared for Ham does have a lot of supporters creating plugins for other modes that are commercial.
Software and soundcard interface is the way to go!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's interesting news - what modes have been added to MixW with plugins?
73 Mike
K
kb0nly
Guest
73 Mike
You would have to go look at the yahoo group or the links on the MixW page, i don't know for sure what all is available... I have added a few here and there, but so far i have just added the stuff i wanted to try on the ham bands.
n2pqq
I would say try multipsk
index
Messy interface but works very well.
burts
Devon
HI
I HAVE THE IC R2500 which port is best to use for pager decoding data, speaker, packet 1 or 2 i am using pdw but get lots of unknown sync header a6c6aaaa
many thanks
