Using Fleetsync On Kenwood 2312
btritch
Paragould/Greene County AR
Does anybody know what the secret to using fleetsync on the Kenwood 2312 is? I'm trying to match my kenwood 7160 I have in the truck and some others in the county. I went to the bank. Set the Optional Signaling to Fleetsync, Went into the fleetsync setup menu, Setup a Number Fleet and Own ID's and set it to EOT End Of Transmit but when I try to write to radio I get a write error EOT Transmit.. How Do I Fix That? What am I doing wrong?
Av8tor56
Roswell, NM
I'm not all that familiar with the 2312 but on most of the Kenwoods I program you have to activate the PTT ID in the channel by way of channel edit.
Av8tor56
Roswell, NM
The only other thing I can think of is to look in "Optional Features" and check if the signalling in there is set to MDC 1200 or DTMF. You may also need to check under Model. Some Kenwoods have to have the FleetSync enabled there.
btritch
I've got everything turned on and set the ID and everything right, The bank is set to Fleetsync and each channel is set to fleetsync, That's fine and when I go to each channel edit and select EOT or BOT or both I get an error message..
Av8tor56
Roswell, NM
I'm looking at the software for a 2360 so bear with me. It sounds like you're set up ok but is the FleetSync enabled in the Model Information menu? On the 2360 it is defaulted to MDC-1200 so if everything else was set up you'd still get an error as it's looking for an MDC ID. I don't know if it's the same as a 2312 but it might be a place to look.
gadget0308
Portland, Maine
I have figured out the issue. Under the edit menu on the top, go to optional features, go to common 2, and change the PTT ID TYPE from DTMF to FLEETSYNC/MDC. This will fix your issue
nick223
Ottawa Illinois
i have the same radio i never had a problem with programing fleet sync into the radio just make sure each channel is slected to accept the id. also under fleet sync make sure the caller id box is checked....nevermind i just say you fixed the issue lol
