Using Metal Fence as Antenna
Mcoatmeal1
Marathon County Wisconsin
I’m wondering what benefits can be achieved if I use my metal fence as an antenna for UHF/VHF reception. Is it advantageous to use the 6-foot high fence vs. a normal "rubber ducky."
ridgescan
San Francisco, Ca.
You won't find it effective at those frequencies. The higher the frequency, the shorter the antenna. That fence, depending upon its length, may make a killer shortwave receiving antenna:)
Check out this link
Antenna Calculator
key in a frequency you want to find an antenna length for, and you'll see what I mean. For example, 488mHz only requires 11.5" of antenna for a half-wave.
wtp
Port Charlotte FL
ground
an old trick (don't know is it worked) was to use a fence as a great ground for c.b. radio
with a chrome fender you would park into the fence and done!
some say it worked but i never tried it
