thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,890
Up until recently, I've only ever needed to use two (RTL) SDR dongles at the same time.
I just use a 2 way splitter for the antenna.
What are people using when connecting more than two dongles to the PC and sharing the same antenna.
I know the more you split it the more the signal is affected/attenuated.
Are people using a 'all in one' splitter with amplifier (distribution amplifier?) or using a individual splitter and amp.
Are you amplifying at antenna (mast) or at the antenna in to splitter to improve gain or some other configuration?
Any amplification really only needs to try and over come the insertion loss and splitter loss as I'm in an RF strong area at the moment.
Frequency range of interest: 100-900MHz
Any product suggestions?
I'm planning to use the dongles at a reduced bandwidth (229376 SPS) with some decimation applied (x8) for a final bandwidth of approx. 23 Khz.
This will reduce the bandwidth of each dongle on the USB as well as reducing CPU for each of the SDR# used which should allow for more SDRs to be used.
Thanks for any suggestions.
