Binger511
I understand that it may not be ideal, however its what I'm working with/experimenting with at the moment. Right now I am using a Kenwood TK-8180 with a KRA-27 UHF portable antenna inline to a "PL259 Male -->SMA Male" attached to the mounting bracket. I very rarely ever transmit, and when I do it is on low power and only for a few seconds. (Basically just a scanner at the moment). I got some confidence that it would work when I saw a Kenwood Kairos DMR repeater video where they have the same basic setup with a similar setup as seen below:
I am open to criticism/tips to see if there is anything I can be doing that could make the setup better. Or if what I am doing should be stopped immediately due to spontaneous combustion of said radio. My setup:
