Using RS cable with PSR-500
Stick0413
Hopewell, VA
#3
Yes it is the same cable that came with the PSR-500. Only difference is its is orange and has RS branding -vs- the blue GRE cable. GRE was the OEM of the RS cable.
Dover, NH
#4
Ok, just wanted to make sure if I decided to go with a GRE scanner instead of my Uniden, I'm glad I can keep my current RS cable without buying a new one.
Thanks guys!
Ames, IA
#5
Thanks guys!
The PSR-500 comes with the cable included.
Dover, NH
#6
haha, figures, I guess if I find one on eBay (unlikely), that just includes the scanner, i'll be set.
I know this isn't the best thread to ask, but would you recommend the PSR-500 over the 396T? I just got the 396T but I can't get it to decode any digital transmissions, and I really like how the 500 is setup, with all they buttons you need on the keypad.
ScanTheFreqs
Banned
#7
yeah you're right its not, but since were here, i had a 396t and wasnt by any means 100% satisfied with the digital sound quality, (analog/conventional sound great) i told myself i'd hang on to it until the 2.0 update and see if that helps, well i waited, and the update did not bring me the results i wanted, so after reading all the comments on how well the sound quality is on the psr500, i decided to buy one of those, complete night and day difference, if your buying a scanner to LISTEN to, then sound quality should be your main issue, and if that IS indeed the case, i recommend the psr 500
Dover, NH
#8
Well right now I have both the PSR-500 and 396T, I went down to HRO yesterday and picked up the 500. It worked great at first, but now I can't get it to pick up any signal, and I mean anything. It just keeps on scanning through the weather channels as well, and I have no idea why.
The only time it works is if I'm near the transmitter, or if I tune to a ham frequency and transmit.
takeme
Was Oakvillecub
Banned
Halton
#13
can i use my pro96 or pr92 cable for my psr500?
hi all, i have a pro96 and a pro92 cable and they are both serial instead of usb, can i use one of these for my gre prs500c scanner?
thanks
