Thank you so much!Hi & welcome to the RR forums:
What country(ies) will you be visiting? From the RR database main page, choose country here (as outlined in red). Note that not every country has identified info but that's how you can check
I did not know that an European Version existed, will look into it. But I can straight away guess that being more rare model, it will cost even more that SDS-100 (which is already quite dear).If the plan is to use it in Europe, shouldn't you consider buying an SDS 100E? I think Europe may use some different frequencies and band plans. Not blocking US cellular might be an example.
I am working on project in Moldova at the moment (yes, former Soviet blocAnd before bringing a scanner into Europe, check with someone for rules and regulations. I wouldn't even think of bringing a scanner to a former Soviet bloc country, for example.
Mike
In that region it's sometimes illegal to own a radio that can receive the frequencies that military and police are using. So try to check if a scanner are allowed in Moldavia.I am working on project in Moldova at the moment (yes, former Soviet bloc), but was able to get my amateur radio license here...
It's usually prefered to get a US scanner model as updates and bug fixes are more supported than for other regions. But as the SDS100 probably are the most problematic Uniden scanner ever, and that could need to be sent to US for repairs, you still might be better off with a EU purchase. People selling their scanners might be unsatisfied with them due to some issues that turns out that it needs to be repaired.
/Ubbe
Also, emergency services in most (all?) European countries are encrypted (often Tetra) which the SDS100 nor any other scanner will be able to pick up
