I currently have a 6 port serial card in my windows computer - and it works fine with serproxy + monitor to send alpha tags to my streams.
I picked up an Edgeport 4 port USB to Serial adapter. We use these at work and they are nice little devices..
My problem is, I can not get serproxy to open the ports. I constantly get "failed to open com port - connection refused" in the serproxy window.
If I use BuTel to read the scanner through the Edgeport, the data passes fine, so I know it isn't a com port issue..
Can serproxy ready serial usb ports? If so, how would I configure it? I've defined ports 11 - 14 as the Edgeport serial ports.
Here is my serproxy.cfg file:
Thanks for the help.
Code:
# Config file for serproxy
# See serproxy's README file for documentation
# Comm ports used
comm_ports=11,12,13,14
# Default settings
comm_baud=19200
comm_databits=8
comm_stopbits=1
comm_parity=none
# Idle time out in seconds
timeout=-1
# Port 11 settings (ttyS0)
net_port11=5331
# Port 12 settings (ttyS1)
net_port12=5332
# Port 13 settings (ttyS2)
net_port13=5333
# Port 14 settings (ttyS3)
net_port14=5334
