plutonium233
- Joined
- Mar 31, 2008
- Messages
- 59
- Reaction score
- 2
I recently set up a BCD536HP on Proscan for a radio feed and remote control. I work away from home a week or more at a time so I rely on this functionality to be able to access the scanner and its feeds. However, I found out today the Wifi dongle is set up for DHCP. There was a power outage where the scanner is located, but when the scanner came back online, it was inaccessible.
I was able to guide a friend through some troubleshooting over the phone, and it turns out the Wifi dongle's IP address had changed when power was restored. This meant I had to explain how to change the Com Port URL IP and the Audio Control URL IP to the correct one so that service could be restored.
Does anyone know how to change the configuration such that the Wifi dongle can be assigned a static IP address? If I could do so, I would be able to make the entire system come back online without any need for local intervention.
