Utah Mil Air Database
bbrasmussen
Woods Cross, UT
I'm trying to organize scan lists and start monitoring Mil Air activity. I'm very familiar with VHF Civil Air Frequencies, but not so much VHF and UHF military air frequencies. So I'm very reliant on the current RR database.
In the database I've noticed there are numerous entries with conflicting tags and descriptions. Any comments/suggestions would be nice, so I can clean up my scan lists and tags with information that makes sense. If there is a consensus here, it would also be nice to submit changes to the database so the duplicate frequency information is consistent with itself.
The list follows. In each pair the first entry comes from the Utah Military, Utah Test and Training Range subcategory. The second entry comes from the Utah Military, Military Air Frequencies subcategories.
Code:
141.60000  M	UTTR A-A 18 Air to Air
141.60000  M	F-16 Air 12 Air to Air Ops - 388TFW/34TFS
226.00000  BM	UTTR 01 UTTR
226.00000  BM	Range Clover Range Control Operations - Clover
229.20000  BM	UTTR 02 UTTR
229.20000  BM	Range Ctr 1 Range Control Operations
233.40000  BM	UTTR CLOVER	CLOVER Misc.
233.40000  BM	Range CtrMOA	Range Control Operations - Sevier MOA
239.90000  BM	UTTR 03 UTTR
239.90000  BM	Tac Training Tactical Training
266.30000  BM	UTTR 04 UTTR
266.30000  BM	Range ALCM Range Control Operations - ALCM Comms
269.90000  BM	UTTR 05 UTTR
269.90000  BM	Maint AFLC Maintenance Operations - AFLC
271.10000  BM	UTTR 06 UTTR
271.10000  BM	Range ClovrS Range Control Operations - Clover South
275.90000  BM	UTTR 07 UTTR
275.90000  BM	Range Ctr 2 Range Control Operations
287.00000  BM	UTTR 08 UTTR
287.00000  BM	Range ClovrN Range Control Operations - Clover North
298.60000  BM	UTTR 09 UTTR
298.60000  BM	Range ClovRN Range Control Operations - Clover Range LL North
301.70000  BM	UTTR 10 UTTR
301.70000  BM	Range ClovRS Range Control Operations - Clover Range South
311.30000  BM	UTTR 11 UTTR
311.30000  BM	Range ClovrG Range Control Operations - Clover GCI
315.90000  BM	UTTR 12 UTTR
315.90000  BM	Range Ctr 5 Range Control Operations
324.70000  BM	UTTR RangeCt Range Control Operations
324.70000  BM	Range Bomb Range Control Operations - Bomb Range TOC Wildcat
327.40000  BM	UTTR 13 UTTR
327.40000  BM	Misc. Net Ln Misc. Net - Airborne Launch Control System
327.60000  BM	UTTR A-G Com Air to Ground Communications
327.60000  BM	Range Ctr 7 Range Control Operations
339.00000  BM	UTTR 14 UTTR
339.00000  BM	UTR Clover	UTR Range Control Primary - Clover
344.90000  BM	UTTR 15	UTTR
344.90000  BM	Range R-6404	Range Control - R-6404
351.00000  BM	UTTR 16 UTTR
351.00000  BM	Range Eagl Range Control - Eagle Weapons Range
354.40000  BM	UTTR 17 UTTR
354.40000  BM	Range Ctr 8 Range Control Operations
363.50000  BM	UTTR 18 UTTR
363.50000  BM	Refuel ATC 2 Refueling Operations Exit Contact ATC AR648-B
375.90000  BM	UTTR 19 UTTR
375.90000  BM	Eagle Range Eagle Range Control "Craner"
383.20000  BM	UTTR 20 UTTR
383.20000  BM	Range Ctr 10 Range Control Operations
384.70000  BM	UTTR 21 UTTR
384.70000  BM	Range Ctr 11 Range Control Operations
388.10000  BM	UTTR 22 UTTR
388.10000  BM	Range Ctr 12 Range Control Operations
398.10000  BM	UTTR 23 UTTR
398.10000  BM	Range 299CS Range Control Ops - 299CS
theaton
Member N7VU
Moab, Utah
Has anyone monitored the military air band enough to know if Hill AFB uses AM exclusively or a mix of AM & FM? Has anyone heard from gldavis lately?
gariac
I haven't monitored Utah, though I suppose next time I'm on a Nevada mountain top I should give it a try.
Generally speaking, all aviation is AM except for low band, which is FM. CAP is FM IIRC, but I haven't monitored CAP in a long time. The military aviation lowband is usually A-10s, but that might just be a function of where I have monitored.
I went through what official documents (as opposed to what people post on the internet) I have for the UTTR and came up with this:
Clover Control 134.1 363.5
KDPG CTAF 126.2 270.3
CLOVER CONTROL, (UTAH TEST & TRAINING RANGE) UT KHIF ANG
UTC-7(-6DT)
REMARKS - MISC -Ctc CLOVER CON DSN 777-7575, C801-777-7575. All acft opr
on UTTR must sked thru 388 RANS/DOOS DSN 777-4401, C801-777-4401.
COMMUNICATIONS - CON- Opr 1400-0700Z++ Mon-Thu, 1400-0100Z++ Fri,
1500-0000Z++ Sat, exc hol. (R) (E) (118.45 282.375 285.65 VFR/IFR svc in R6404A, B, C,
Lucin MOA) (134.1 363.5 316.05 VFR/IFR svc in R6402A, B, DPG, R6405, R6406A, B, R6407,
Sevier MOA, Gandy MOA, Gandy ATCAA, AR642E, W, AR659.) H-3C-D, L-9C-11C
HILL AFB
COMMUNICATIONS - SFA PTD -139.3 371.95 ATIS -134.925 397.9
SALT LAKE CITY APP - (R) (E) 121.1 124.9 126.0 126.8 135.5 257.875 290.3 307.2 316.15
316.7 319.25 REMARKS: Class B Airspace TWR - (E) 127.15 263.15 251.05
GND -121.6 275.8 SALT LAKE CITY DEP - (R) (E) 121.1 124.9 126.8 290.3 319.25
REMARKS: 381.2 CLNC DEL -124.1 335.8 COMD POST -381.3 REMARKS:
ACC-RAYMOND 23, others CONVOY. PMSV METRO -Avbl 1200Z++ Mon - 2300Z++ Fri,
clsd wkend. 342.3 REMARKS: Unuse 010°-100° byd 20 NM blw FL 200, 101°-150° byd 25
NM blw 15,000'. Wx obsn not fully rpt 120°-260°. Ceil and vis are freq lower on the N end
of the rwy. KDMA AFB is the hub for WX info DSN 228-7647.
MICHAEL AAF
COMMUNICATIONS - CTAF -126.2 270.3 CLOVER CON SOUTH -134.1 363.5
FIRE STATION - (E) 126.2R DUGWAY RANGE CON -36.1 126.2 270.0
FSS-CEDARCITYCDC-NOTAMCDC
