UV-5001 Gen2 Original Chirp Image
BFE
#1
I was wondering if anyone had an original chirp image for a Baofeng Tech UV-5001 Generation 2 with firmware BTG214. I seem to have the same problem as some of the ht issues of the image getting corrupted when being uploaded to the radio. I can only hear an audio transmission when I press the monitor button or set the squelch to 0. Please note that the squelch settings or tone settings are not the problem. This has been well documented with some ht images getting corrupted when being uploaded and only an original image file will fix the issue. I tried to upload the same image to my radio that I uploaded months ago and the only thing that was different was the newer daily version of chirp. When I reverted back to an earlier daily version it did not solve the issue. Resetting the radio or loading the default settings with the oem software were also ineffective. Also the problem is the same if it is in vfo or memory mode. I have sent a bug report to chirp so they can investigate it further. I know I should have backed up an image but I like to live dangerously. Thanks in advance for any help.
BFE
#2
I'll even try a current working chirp image if anyone would be willing to share the file. I have had no success on getting an original chirp file from Baofeng Tech either so I am willing to try anything at this point.
PA
#3
There is a bug in several versions of Baofeng firmware where receive gets screwed up when you turn the key beeps off. Try turning key beeps back on (Menu 8 IIRC) and see if your problem goes away.
BFE
#4
I had forgotten about that and I just tried that with no luck. :(
BFE
#5
Still nothing...
Well, I became desperate and bought the RT Systems software and cable. I tried to reprogram the radio with no success. I guess CHIRP really screwed something up in the radio. Does anyone have any ideas or any kind of images(CHIRP, RT Systems, Factory Software) I could try? I did receive an original image from BTech(non CHIRP) and that was unsuccessful. :(
BFE
#6
Please Help
I'm going to try one last time and ask for help. Does anyone have a UV-5001 Generation 2 chirp image I can try and use to bring this paperweight back to life? Otherwise I'm gonna chuck this thing in the trash since BTech is of no help and basically have ignored my requests for more help. Whether or not I get this thing working, I have decided that I'm only going to buy real commercial radios in the future.:)
