Baofeng UV-5R programming question
hotpocket
I was just wondering if anyone knows of a way you can make a programming file, (I guess sort of like a codeplug) so that you can swap out memory banks on the computer without having to program each frequency individually. Like some days I may want to use the UV5R to listen to rail frequencies, and other days I might want to scan a variety of frequencies. If there is an easier way to program it, I’d be very grateful
hotpocket
Oh, so if I save a separate profile in CHIRP for each sort of “favourites” list, I should be able to just load the profile and write them to the radio
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Just program ALL of your radio channels within numerical groups... example: 01-25 = ham; 26-50 = railroad; 51 -75 = fire; 76 - 100 = law; or similar groupings. Then they will all be available just by spinning the dial.
nd5y
Wichita Falls, TX
You could do that but Baofeng radios don't allow you to scan banks/zones or add/remove channels to/from the scan list. If you only want to scan certain things at one time then you need to make separate files.
mpatch
N Colorado
That's not true. You can select "skip" as an option in chirp. I have about 110 saved channels and I have all but about 12 of them set to be skipped when scanning.
As for having separate scans saved on the HT that's not possible nor is scanning only a frequency range like you can on most higher end units.
