Baofeng UV-82 file?
glock35ipsc
Fort Collins, Colorado
I tried search but didn't find what I'm looking for. Kind of a noob, so I'm probably using the wrong terms.
Is it possible to find the file that has all the factory installed frequencies on the UV-82 that can be downloaded? I would like to add those freqs to my UV-5R radios. I could just copy it off one of our UV-82s, but being stuck at home for who knows how long, I won't be able to get to one in a while! :LOL:
Thanks in advance!
KK4JUG
GA
Unless things have changed, none of the pre-installed frequencies are usable in this country so, theoretically, they would be useless.
nd5y
Wichita Falls, TX
Its not a file but there are lists of CCR default frequencies at:
There is no guarantee that those are current or the same in all radios made at different times by different manufacturers or different firmware versions.
KD8DVR
Columbus, Ohio
You need to program your radios to the frequencies you are licensed to use. The factory frequencies are just test frequencies used at the factory.
