V0.93-0.17K-R02 Firmware Discussion
MBECKNELL
Hamilton,Ohio
ok guys i need help with installing firmware i have downloaded it from the email but the loader can find the firmware image. i would like help or input also the firmware loader says it is looking for the pager
matt
Jimco
Dallas/Fort Worth
This one's not going so well for me. I successfully flashed the firmware, but every time I receive a transmission, my radio crashes and reboots. I'm going to try reflashing it now to see if that helps. :(
Second problem solved. It must have been a bad firmware flash. I reflashed it and all appears well now.
Jimco
Dallas/Fort Worth
If you start PPS, does it see the device? The radio should show "PC Connected" when you start PPS.
troymail
Silent Key
Interested in seeing this in action.... but assume based on the way it is written there is no change to the mute status.... we'll see.
Added “encryption” icon in the UI and the message box record list for received encrypted messages.
ok - I see the little shield in front of the radio ID when the voice call is encrypted... no muting (but that wasn't listed as implemented so I wasn't expecting it to be). Seems to display the shield for both programmed talkgroups as well as in wildcard/monitor mode. Hopefully, this is a precursor to a future mute (or skip) solution.
David_Oney
Former Unication Tech Support
Raceland, KY
DO NOT use the portable dealer Uni Maintain Tool. It Shouldn't have even been in the release folder. I must have overlooked it. That utility requires different drivers and the unit to be in an engineering mode for it to work correctly.
David_Oney
Raceland, KY
That's what I am trying to get implemented.
Jimco
Dallas/Fort Worth
FYI, the reason I recommended this is because the firmware updater doesn't provide the same level of info. PPS will show you if the device is recognized no matter what. The firmware update can seem to indicate it doesn't detect the device for various other reasons it seems.
David_Oney
Raceland, KY
To determine whether the unit is connected you can check the device manager under network adapters. It should show Unication USB Ethernet/RNDIS #X. Also you can Ping the IP using the command prompt the IP is 10.10.0.12.
mdsxfire
EDBM
Uxbridge, north of the river Thames
I have pps installed but do not have my pager yet. What is the correct order to plug everything in so the PC recognizes the pager and installs the driver. Or are there drivers somewhere I have to install?
elrod
R'ville,IL.
I haven't seen it mentioned for this new firmware release yet.
Do we still have to change all the knob function settings to tone from silent, or we get the dreaded
speaker X again.
Chuck
David_Oney
Raceland, KY
The driver installs at the beginning of the PPS installation so always install the PPS before connecting unit.
troymail
Silent Key
I'm using Windows 10 and I did nothing special beyond installing the PPS and running the firmware updater. Best I can tell, the only sequence required is to ensure the radio is connected via the USB cable and powered on before pressing the Download button on the updater tool. If the updater can't find the radio, it will tell you.
David_Oney
Raceland, KY
WX4JCW
Stow, Ohio
One thing to possibly do as well is once the new firmware is installed, open the pps and make sure your codeplug is ok and resend it to the pager, don’t think it’s necessary but I did have one profile get borked
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
