VA Veterans Admin in Johnson City
DonnieDog
Database Admin Deluxe
Elizabethton, TN
Does anyone know what type system and freqs the VA Veterans Admin uses in Johnson City? Like for their police and such. How are they licensed and listed? It will probably listed under Mountain Home, TN
Re:
Im down in Jc right now, never thought about it Other than HEAR or a Med Comm Chs I would say they use Intersquad radios for intrafacility use like maintenance, nurses etc... Military "FRS" equivalent, try 396.8750 to 400.0000 FM
maybe nextel, good point tho u think wed heard em by now
btw donnie i got loads of new unit numbers in the radiophonebook check em out on the spreadhseet tab "agencies
Im working on some right now and will have annother 50 or 75 or so uploaded by tonight,
Im stumped on Hawkins County Sheriff's Office
202
209
325
353
608
800
807
903
, I think i've figured out Sullivan County....but im still wondering if THP is talking to Sull county or if sull county just has 55xx unit numbers as deputies too
Anybody please chime in if your familiar with the unit structures :)
ecps92
Taxachusetts
I would suggest spending sometime searching 406-420 [Where most of the VA's are moving to from VHF] as well as 162-174 Mhz
I've not seen any VA using ISR [IntraSquad Radios], altho GMRS/FRS is not out of the question from time-time.
DonnieDog
Elizabethton, TN
Good deal Mike, Im gonna try and work up some more things for you too. I gotta get it from paper to pc!! Thanks for the help, Im headed to work at 7 so youll be hearing me later.
CORN
Nashville, TN
Don't know about Johnson City but here in Nashville the VA Hospital Security uses 408.0 in P25 and NAC Code is 283.
DonnieDog
Elizabethton, TN
Anyone else in JC or close by try these two freqs 407.8375/407.840 (im sure they are using the 8375 but making sure) if you can for the VA. I found these last night as I know it is the VA, but I cant find a PL or DPL. Kinda puzzled on what type of system it is. Im getting a quick squelch opening every 5 sec. Could this be a trunking system or? Thanks for any input
INDY72
Indianapolis, IN
This is an LTR Passport. You verify this by the mention of the data burst every few seconds.
http://www.radioreference.com/apps/db/?sid=6293
It is NOT trunktrackable by any current generation scanner. There are two ways to monitor an Passport LTR system.
1: Conventional with NO delay on ANY repeater freq, the frequent data bursts will lock up on the freq.
2: There is an trick with the PRO-96/2096 where I believe you set the bank its in to conventional, but the freqs as Motorola. This cuts the data bursts down to a minimum.
