Vatican Antenna Question
ab5r
During the TV coverage of the Pope leaving the Vadican, a fly-over view showed a impressive antenna and tower. The antenna wa obviously two log-periodic type antennas, but their points merged into what may be described at a V shape on its side. Anyone know the brand of this antenna? Thanks.
Jerry AB5R
W2NJS
Washington DC
A similar antenna is located on the Vatican Embassy on Military Road in NW Washington DC. There was another of the same LPV type mounted for years on a tall office building (now condo apartments) in Silver Spring, Maryland, at 13th Street & Georgia Avenue. The story was that this one was owned by NOAA and was used for monitoring electronic weather buoys in the Atlantic Ocean.
ab5r
Hmmmm? Thanks. Still would like to know Brand etc. Thanks again.
ab5r
Yes, Mike, it could be, but I am interested in learning about that dual log-periodic V-shaped antenna.
ab5r
Received another message from KD5RKO describing the antennas seen:
"That's a stacked array...the reason the arrays aren't parallel is so that the relative spacing is optimum over the entire frequency range of array. At HIPAS, we had a PYRIMID array of 4 wire log periodics for our ionosonde."
Thanks to ALL & 73. Jerry
