jeepon02
- Joined
- Apr 28, 2005
- Messages
- 10
- Reaction score
- 0
Hello, I was not sure where to post this, just taking a chance someone has used this equipment.
I have two VEGA IP223 that im using to convert 4wire audio to ethernet data and back. So i am by no means am i using this equipment to its full capacity. All i want to do is make a 4 wire circuit over ethernet.
Setup will be Zetron 4048 EDACS console using tone card. (so basic tone remote) from zetron to IP223 radio 1, this converts to 4wire to ethernet over our network. Ethernet comes into IP223 on far end converts back to 4wire. From there out to a CPI tone remote board. to EDACS 500M radio.
Basic tone operation 2175 gaurd tone 1950 function tone and it will key the radio, but not everytime. I have checked set and reset levels. they are good.
The IP223 will do 16 functions, if i put out a 1650 from the console the IP223 will generate its own 1650 and send it to the far end. that is the problem. Some where in the ethernet path the 1650 gets changed, or so the far end thinks so, as it will RX a totally different function tone. I thought this would be in level setting or RX AGC but its not. The only way I could get these units to work in the first place was to have them both configed to TONE. tech support say the one at the Zetron has to be set to Console mode and the far end to Tone mode. Tried this and no luck.....not much luck with Tech support..
anyone using this product to make 4wire over ethernet that could share some programming secrets?????
thanks all
Ken
thanks all
Ken
