ARC536: Version 2.2 Build 7
garys
I just downloaded and installed the latest build, but I can't see what's new or changed. Does anyone know?
Thanks.
u2brent
OAMPT
KRWDPAXKRS1
Is it just me? Or is the signal meter on build 7 non-functioning on the BCD VC display? :unsure:
Rolling back.. :(
had to go back to arc536pro_201_build8
ZL1UOJ
Will the ARC536 basic version get updated for the new 3 filter options - wide normal, wide invert & wide auto.
Thanks.
Ravenfalls
Thanks.
Testing filters & Invert works best 700Mhz +.
Low noise Wide Invert good.
High noise Invert decodes best.
VHF & UHF back testing Normal.. Go back use Butel without loosing our manual input of wide setting.
So Far Away....
Any way to allow a registry entry so uninstall / installs do not require a re entry of the 2 keys..
Love the ARC line of software...Drives me buggy though.
Thats my Saturday Morn Gripe....
AA6IO
Cerritos, CA (LA County)
I tried using the new VC for SDS scanners yesterday with my 200 and keeps crashing on Windows 7 after few minutes. Repeatedly happened 4 times. Unable to use for logging. Never had this problem with Butel VC for any scanner previously. Previous version VC worked fine with SDS200. Anyone else seeing this problem. Please advise.
glenknyc
Staten Island, NY
Starting with Version 6, I have noticed a logging issue which seems to occur with AM transmissions, where data is not formatted correctly into the proper column.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Why in the last 2 versions that whenever you read a file from the scanner into the software that it automatically opens up every single system/site. They used to be all closed but now it opens every single item up. I had posted this issue in another thread but it was the wrong thread and I only got around to posting about it here.
I just got around to updating to the latest version and noticed that this was still present. This didn't happen in a few earlier versions.
Much more presentable when it doesn't open everything up and it's all in collapsed mode instead. Can we get a fix on this in another update please?
