Vertex CE82 VX-2200 problems
#1
Hi Guys,
I have this problem with my brand new radios,2 VX-2200.Well the problem is about the comunication from PC to Radio.
Naturally I'd like to inform you about my configuration:
RTX : VX-2200E
USB programming interface : FIF-10A
Adapter cable : CT-104A
SW : CE82 ver.1.10W
Ok,when I launch my SW and choose the button "upload" the RTX'S display go in SELFTEST + TONE (listen),appair NOW UPLOADING (on PC SW) and error message appair COUNICATION ERROR!
Naturally the RXT return with VERTEX channel name in OEM configuration.
So I try to change the SW CE82 in ver.2.0 but obtain the same error.
The USB programming inteface is good install with right driver under Windows XP
Really,I don't know what I do.... :-(
Thanks for all and I hope to receive some support.
(...sorry for my elementary english (US))
#2
Try changing your com port the software looks at to read the radio. on my pc it uses com 1 one laptop com3 the other com 5
Indiana
#3
programming
on the vx-2200 radio ,, i had same problem ,, and could not figure it out ,,, thought it was comport problem... i called my radio dealer action communications and he told me i need to update my firmware version,,, so for $20.00 he sent me the updated version and that fixed it i was able to programm radio ,,, thanks matt
