Vertex vx-824 backlight bug?
Danny37
New York City
#1
So I have my radio with the backlight to be enable with every "key on" it works fine but when I install the vdme-200 in the back of the radio. The backlight stops working after like 20 minutes, the lamp key still works but the "key on" feature doesn't work. Turning the radio off and back on usually resets it but anyone know a work around for this bug.
the radio has the latest firmware version of 3.03.
Danny37
New York City
#3
the board keypad is disabled on CE73 but it just seems like the lighting situation to due to the board itself. When the board is out, the key on lighting feature works fine but the board is in it goes out after 20 minutes.
Oregon
#4
Hmmm? Yeah that was just a thought. The time frame is what's really weird. I used them in the 420s and 4200s when the VMDE200s came out and got a bunch of info from the mfg. I see if I still have the schematics.
