Vertex VX-924 Programming
TechTom
Berwick, PA
I am programming a Vertex VX-924 portable radio. I want to set it up for one channel to act like a Minitor V pager. I want the radio to be like the pager's "SELECT CALL" mode where the radio is silent until the tones go off, then open up, and remain open until manually reset back to "SELECT CALL". I don't want to listen to everything on the channel until the tones go off.
I have entered the tone set and the radios reacts to those tones by beeping as it should. However, I can't figure out how to silence the radios until the tones go off. Can you help?
gvodvarka
Ontario, Ca.
Two-Tone Decode
If you program Page in the signalling and nothing in the Dec the radio should not open monitor the channel. If you hit the PTT it will monitor for the time you set until it resets. Gary
TechTom
Berwick, PA
According to the HELP menu, "PAGE" is only used for DTMF signalling. I tried your suggestion and it does not respond to the 2-tone sequence used by Minitor V pagers which I programmed.
