Vertex vx454 channel announcements
firebell9137
Hi. I own a Motorola/Vertex vx454 vhf. Can anyone help me on how to make and download voice announcements for the channel names in the radio please? Any help would be great. Thanks! Not sure where this should go in the forums so i put it here as well ad Motorola forums. Admins please delete if u need to only have one. I thought Vertex was taken over by Motorola.
MBill
This may help you. I assume you have programming software. Open the programming software and click
on the "Common" column. Select "Ch Announcement". In the box that opens you can choose the default
"English woman" voice and download it to the radio. Be sure to enable the Ch Announcement check box.
Or you can click on the "Make File" box and create your own voice file. There is a "Help" menu associated
with the "Make File" menu that tells you how to record your voice message.
Just note that you have to download the voice file separately from your other programming, it does not
automatically download with the frequency, tones, etc.
The above is the for Vertex VX-454 portable. I assume Motorola has not changed the procedure with the
Motorola version.
Bill
