Vertical separation question…
mass-man
trying to retire...
Parker Co., TX
Between a 6mtr horizontal loop and a 3 element 2 mtr beam. Separate rigs so trying to keep one or the other from possible front end damage!
How much power are you talking, MassMan ?
You are probably safe as long as they aren't actually touching each other, and the power is <50 watts +/-.
Seriously, several feet of separation should be just fine. they will de-sense each other tho if you are trying to do both bands at the same time.
mass-man
trying to retire...
Parker Co., TX
GRACIAS....not both at the same time, and only the 6 mtr rig could max out at 75 watts or so...the other is an ancient TM 751 that no longer puts out the whopping 25 watts it was advertised to do, but more like 15-18 watts. Weak signal is my middle name!!!
