I recently came across a 36" - 3/4" od 5/8" id copper tube, 101 alloy...
I am surrounded by the ocean, so I was thinking perfect length for a marine band dipole to place on my mast.
A nice wide band, low noise floor, antenna, to listen to all the boat traffic from Hudson canyon to NY harbor. Transmit also, And a chance to build my own antenna.
I know there is nothing compared to free space, but I would like to have as little loss as possible. Maybe some day use it with my icom busisness band repeater.
Instead of mounting the elements inside pvc nipple, electrical junction boxes, etc... (that can be found in plans all over the internet....) I was thinking of mounting the elements with a piece of 5/8" od fiberglass (inside the tube) and run an perpendicular 18" fiberglass pole back to the mast with feed line and quarte wave matching stub.
No fiberglass over any part of the elements but inside with a little jb weld and soldered feed line to the elements. Bare Copper Antenna.
Given skin effect, on the outside radiating part of the tube. Would fiberglass inside of copper tubing effect the impedance at all or (at the least) less than having the element emerge from a pvc conduit connector or plastic, making contact with the outside radiating part if the element.
My feed line will be a 20' piece of messi broad 10 solid copper with copper foil and copper braid I had left over from my uhf antenna.
Any Thoughts?
thanks ,
d
Any Thoughts?
thanks ,
d
