The G4 and G5 pagers would work on the Monmouth County system but can scan only one of the sites and a single system at a time. They have excellent decode for P25 Phase 1 and Phase 2 simulcast systems. The G4 receives 700/800 MHz only. The G5 receives 700/800 plus VHF
OR UHF, depending on the model. You are also limited to 64 talkgroups on a trunked system and the pagers cannot trunk track the older Motorola Type II systems. The SDS100 and SDS200 give you much more flexibility for scanning multiple sites and systems and also receives both VHF
AND UHF. They can also be upgraded to receive DMR and NXDN. It is less expense to upgrade the scanner yourself. You just login to my.uniden.com to purchase the keys. The upgrades already reside in the scanner firmware. You just enter the keys into the scanner to enable them. I am very satisfied with both my SDS100 and SDS200's. In the meantime, I suggest you download and install Sentinel which is free programming software provided by Uniden.
http://info.uniden.com/UnidenMan4/BCDx36HPSentinel Which Radio Shack handheld do you have?
