view radio ids?
jgilbs
so ive got a BR330T and im using it to monitor a motorola type II 800 MHz system. Is there any way to set it up so I can see who is transmitting (i mean which particular radio, not which talkgroup). I have all the radio ids, I just want to identify who is making the transmission.
cristisphoto
Alpha tag???!!!
Alpha tag either by hand or with the software...
IF that was what you are getting at...
Other than that there really isn't a way unless you were on the Inside of whatever system you listening too...
the Id's (45877) and subsquent tags (PD Dispatch),
are in the database...
SOooo
AnYHOWS,
Hoped I helped
Crista
