BCD436HP/BCD536HP: Viewing P25 threshold on BCD536HP
Bonkk083
Union, SC
How do I view the P25 threshold I saw videos how to do but it's not doing like it say to do
dave3825
Suffolk County NY
Form Marks Scanners.
These steps work only when you can clearly receive the frequencies. If you are in a weak-signal area or receive interference, these steps will not work. These steps do not compensate for weak signals or signals subject to interference.
P25 Adjustment Mode
Bonkk083
Union, SC
P25 Adjustment Mode
I'm getting 3 to 5 bars while scanning, do I push func and vol at the same time is the funct the big knob
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
If I am getting a good signal and not stopping on any ids
I am not following. What are you asking?
I'll take a stab in the dark and say simulcast distortion. Threshold levels are dependent on different factors. There's no "one size fits all" solution. If you do happen to get one reliable decode after following the steps outlined in post #4 take note of that threshold level. The key is to get the error rate (ERR) as close to zero as possible before setting threshold mode to manual
Bonkk083
Union, SC
Will turning the antenna help
dave3825
Suffolk County NY
An antenna tuned for the freqs being scanned will almost always yield the best results. A little off might not be noticeable with strong signals.
Ubbe
Stockholm, Sweden
I viewed threshold it's showing 6-13 while scanning what should i put in for manual
The scanner are storing the threshold values individually to each site. If you are scanning then it will show each value from each site as you scan them.
If you program a site or frequency department to use manual settings then initially set it to 8.
Then when you receive a conversation or have stopped on a control channel and the error are more than 7-10 then push the selector knob so that the Fn text are displayed and while that Fn are still on the display you can turn the selector knob to change the threshold value and try and get as few errors as possible. When it starts to scan it will save that setting to that site or conventional department and will use that value the next time the scan cycle comes back to the system.
/Ubbe
