Viking Firmware Update - Issues
coleprato
Hello,
I have a VM7000 (VHF and UHF) decks. It was working fine until I did a firmware update and not when I power on I get the Viking Logo and then Error Radio Failure on a Red Screen. I have checked all the connections and everything is good. It is also not discoverable any longer on my PC via USB.
Thank you for the help!
P25-logger
Is this a dual deck configuration? Connect the Primary deck to the laptop, then push and hold the power button for about 15-20 seconds. It kind of does a "soft reset" and gets it out of the loop. Then reload firmware starting with the primary deck then secondary. I have had to do this on a few VM7s. I would assume the same soft reset works on the dash mount to but haven't had to do it there yet
coleprato
Hello, Yes Dual Deck (VHF = Primary Deck). I just tired this and no luck, power on KCH-20RV (hold power button for 15-20) seconds, still get the same error. Secondary Deck is disconnected. Any other ideas?
kd4efm
EL98 Florida
How did you do the firmware update first of all, step by step. Let's start there first.
coleprato
step by step: got firmware 8.46.11 from 2way.shop -> loaded it via Armada. Apply Firmware Update -> 8.46.11 -> Monitored Events -> Firmware Transferred and Safely Disconnect Programming Cable and then after I did that it re-booted and now I have Error: Radio Failure.
coleprato
Spent 1/2 hour on with Kenwood Support (Awesome People) and we could not get it to work, sent back for testing & fixing.
