@boatbod So.. I installed new version of Ubuntu 18.10 fresh. I had this working alright on 14.04 for awhile, but I ran into some compat issues with other things on that old build so i'm building a new. I keep getting hung here when its compiling. What am i doing wrong?
FULL LOG:
gist:186f65c39abb4481964a44f466158af2
Relevant Snippet
-- Build type not specified: defaulting to release.
-- Boost version: 1.67.0
-- Found the following Boost libraries:
-- filesystem
-- system
-- filesystem
-- system
-- AMBE Tone Synthesis Enabled
-- Configuring done
-- Generating done
-- Build files have been written to: /home/p25/Desktop/op25/build
[ 23%] Built target gnuradio-op25
[ 25%] Built target test-op25
[ 26%] Built target _op25_swig_swig_tag
[ 28%] Built target _op25_swig_doc_tag
make[2]: *** No rule to make target 'op25/gr-op25/swig/op25_swig.py', needed by 'op25/gr-op25/swig/op25_swig.pyc'. Stop.
make[1]: *** [CMakeFiles/Makefile2:385: op25/gr-op25/swig/CMakeFiles/pygen_op25_gr_op25_swig_75b16.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
====== NOTICE
====== The gnuplot package is not installed by default here,
====== as its installation requires numerous prerequisite packages
====== that you may not want to install.
====== In order to do plotting in rx.py using the -P option
====== you must install gnuplot, e.g., manually as follows:
====== sudo apt-get install gnuplot-x11
