Watch that -v5.. you need a space in there. :lol:OK, last attempt for today: I have it running, using the following command:
./scope.py --args "rtl=0" -N 'LNA:46' -f 774.41875 -S 2400000 -q 67 -v5
You only need to use 0, 10, >10 for the debug levels. A level of 10 will print out the decoded packets in hex form with some detail. Anything greater than 10 will be quite noisy with some low level stuff you probably don't want to see anyway.
Just for clarification, you won't hear any voice decoding with the above command like. That was just a test to see if it can decode the control channel.
To hear voice transmissions, your command line would look like this: (Phase I)
./scope.py --args "rtl=0" -N 'LNA:46' -f 774.41875 -S 2400000 -q 67 -v 0 -V -T trunk.tsv
For Phase II:
./scope.py --args "rtl=0" -N 'LNA:46' -f 774.41875 -S 2400000 -q 67 -v 0 -2 -T trunk.tsv
The trunk.tsv file is a tab delimited file that specifies the system(s) you want to monitor. Open it up in a text editor for syntax... it's easy.
With your mouse over the spectrum plot, scroll up on your wheel to scale it properly.On the Spectrum tab, I see no activity.
Some screenshots would help here. It's pretty much the same process as Windows. Alt-Print Screen for the active window. Check your Documents or Pictures directories. Not sure how Kali has things configured.On the C4FM tab I see plenty of activity. Same for Datascope, constellation, and symbols.
Traffic shows nothing.
Correlation is set to P25P1, but had no effect.
FAC shows nothing.
It sounds like you're not quite tuned on center. If you're close, you should see "tuning error +1200/-1200", or "tuning error +2400/-2400". Use the Fine Tune slider to center things up.
Well, before trashing what you've already spent time on, it would be worth it to keep trying until we can be sure you're tuned right. I promise you, it will be worth all this once you see it work for yourself.I know this thing is close... again I think it just doesn't want to play nicely in a VM session along with bunches of Windoze stuff running too on this machine. But I'd like to make sure I'm not doing something else wrong first before I go the route of building a machine just to have that not work either.
