K3SLS & N6ML...
Thanks for all your input. You're both partially correct in what you think my problems/symptoms are. I certainly didn't want to start a disagreement about this, as except for the lack of an unread message LED, I assumed that my problems were a result of incorrect programming on my part more than anything else.
First, let me clarify that the tones I am talking about are NOT the QCII alert tones transmitted by dispatch. The way I have my pager set up, it doesn't start recording until after the alert - which isn't complete until after the tones have gone out. The only time it ever records QCII tones is if multiple stations/departments are being dispatched with us, and this is not a problem.
I also realize these ARE NOT tones coming over the air.
The tones I am talking about are a beep before and after every voice message. Nine times out of ten there is a beep before and after each message and they are recorded as THREE separate messages. If there is ONE alert, there are THREE messages recorded. TWO alerts, 6 messages, THREE alerts, 9 messages and so on. Occasionally, (and this may be important!) there is only ONE beep message with the voice message.
Why that MAY be important is something one of you said that caused a light bulb to go on in my head. Unlike on a conventional VHF channel (which we still simulcast dispatch on so our Minitors will alert) when the carrier drops - or dispatch unkeys, you can't hear that that's what happened due to it being digial. If, on the P25 system dispatch is unkeying between the QCII tones, and the dispatch audio, the pager might have picked up the tail end of the QCII carrier and the drop and record a beep. Then record the message. Then record the drop from the voice message and insert the beep again. That would explain the Beep, MSG, Beep series I get. It may, occasionally miss the QCII drop beep and then I get TWO messages instead of three. It is also a P25 Simulcast system, which might also be complicating how the pager sees the signals. That being the case, there is probably nothing that can be done other than ignoring the superfluous messages.
As for the binding feature...when I was setting up my pager to decode QCII on the P25 system, Ray from Ray's Pagers said I have to program the binding feature the way I have it of the tones won't decode. I played with that for quite a while when I first got the pager, and it still recorded the two tone messages for every alert.
Thanks, both of you, for all your comments!
Scott
EMT-P-CC
WA2CHJ
