Quote:
Originally Posted by
GumbyCT
Sorry friend, I don't believe it does. There is a timer which can't/doesn't start until the power is turned ON.
Likewise, I don't think it will charge when the voltage is less than 9v either. . .
I suggest you look at the third post in
this thread. While it's true that the timer "can't/doesn't start until the power is turned on", the battery can charge continuously when the power is off. I don't think we'll find a more knowledgeable source of information on the inner-workings of GRE-made scanners than Don Starr.
I hope it is ok to disagree with this thought?
Let me begin by saying "I have NEVER learned anything from someone who always agrees with me". We are just talking here, right? I also hope those with snide, rude comments can refrain from doing so.
If you are prone to get that way, please read no further.
I can only say that if the timer circuit does work with the scanner off and it charges continuously while the scanner is off - that totally defeats the purpose of the timer, does it not?
That would lead me to believe a unit which did charge that way was defective and one should not expect other units to behave that way.
I can say I also experienced what the poster linked above did.
But after reading the post by Don, I decided to put a meter on it and sure enuff there is 9V applied to the battery terminals even with the switch OFF. This is with my newer replacement unit.
I stand corrected - it is this kind of info exchange that make forums a valuable resource. Sharing experiences so others can learn.
I still say it is silly to have that timer circuit work this way, so I am wondering if there were different revisions of boards? Which often happens after production begins and they discover problems?
I guess my thought to have an LED charge indicator would prove to be worthwhile
For clarity - the reply to the above linked post is -
I withdraw my other post. I did not think the internal charging circuit would be active with the scanner off as the little charging icon does not display. That and the fact that I have tried to charge the batteries in the scanner with it off and the batteries were still dead 2 days later when I went to go portable with my PRO-106. I guess I was doing something wrong. I still prefer to charge the batteries externally, as a personal preference. Thank you for the clarification, Don.
ps. I didn't even know that GRE forum existed
Thank You TES and DonS
Edit: Don I tried to PM you but couldn't
Edit2: out of curiosity, I went into the Glob menu and STOPPED the timer - 9v is still present at the battery terminals. Conclusion (mine) is the timer circuit serves NO useful purpose or this thing in also defective, ha!
