RickS31
Well, it probably won't do any harm but the unit is regulated to take that 9 volts from the external power jack down to what the scanner expects for charged batteries. The scanner will operate successfully down to about 4 volts or slightly less when on batteries, provided you've programmed the battery sensor voltages down accordingly (not recommended as you can also destroy a rechargeable battery by discharging it below 1 volt per battery, but I've done it for a test). The external plug is spec'ed at 9 volts DC to provide 6 volts to the scanner (equal to 4 alkaline batteries @ 1.5 volts X 4) plus have the additional voltage to be able to charge the rechargeable batteries, typically about 7 to 7.5 volts. Since you won't be charging the batteries, 6 volts will work but 9 volts is better especially with keypad and display lights on and using the signal LED as well
Hope that helps.
Rick
Hope that helps.
Rick
