SDR# Volume seems low
TDR-94
I have the volume on my laptop set to 100 and the SDR# volume seems pretty low through most of it's range. Only the last few segments of the SDR# volume indicator start to put out decent volume. It there any other settings that affect the audio output volume? I'm not using unity gain,so that's not an issue.
This is using the Airspy R2 and the frequency scanner. Although DSD+ is plugged in over the TCP+DSD+ plug-in,but I'm not currently using it for anything.
iMONITOR
Silent Key
S.E. Michigan
Just a guess but possibly the wrong bandwidth setting, IE: Wide/Narrow.
ArloG
See if you find the Loudness Equalization tick box. That will increase volume levels at the speaker.
