VOX function is not active when tx is over 100m (it is ok when side by side)
tranquangvinh
I have 2 motorola gp-900 radios with repeaters box.
When TX is near the relay it works fine, when the TX is far away from repeater box (over 100m) then VOX function does not work well. RX works well in coverage area.
Please guide how to fix this error.
Sincere thanks
RFI-EMI-GUY
You need to provide more information about "repeaters box"...
tranquangvinh
Hi Sir!
I am using repeater box and two walkie talkie as the picture below.
Sincere thanks
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
You need to separate those radios a lot more or get some filtering. Being that close you are desensitized the RX radio.
tranquangvinh
Hello KevinC
Thanks for replying.
I set it up according to this video.
It will succeed if RX and TX are next to each other, when TX is far away from the repeater box (over 100m) the VOX function doesn't work well.
I unplug the connection cable, RX on repeater box still hears sound
How can I fix this error?
jeepsandradios
East of the Mississippi
Just because YouTube says it will work fine doesn't mean it will. A true repeater has a duplexer and mobile base radios. It's desence as stated. If this is for HAM use there is a lot of options on eBay or other sites. GMRS also has a few part 95 repeaters that are reasonable. If this isn't ham or GMRS then you don't meet any of the rules of your license anyway.
KevinC
32D2T/957.282
Super Moderator
I suspect the OP is not in the USA...or Canada.
tomhank
El Cajon
Verify that the radios have a strong signal when they are far away from the repeater box. Weak signals can cause audio quality problems, especially with VOX. If the signal is weak, consider adjusting the repeater's location or using a higher gain antenna to extend the coverage.
AM909
Radio/computer geek
SoCal
"Desense" means you have RF from the GP900 transmitting radio de-sensitizing the GP900 receiving radio so it can't hear the incoming signal well. Get external antennas for both radios and place them as far apart as possible, both vertically and horizontally.
a417
OP hasn't been on in over a year.
