VP 400/600/900 secondary key function?
Salmon_Glove
Is there a way to add a secondary function to a button on the VP 4/6/900 radios? Is there also a way to have certain buttons or switches perform multiple functions simultaneously? On my NX5300 I have several keys programmed with secondary functions, however, I can't seem to figure out how to program this in Armada or if it's even possible.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I would start by asking which buttons you are tying to use as you can assign soft key functions to the buttons right under the display like you would with an XTS or APX portable and allow you to scroll through them using the directional pad. Like Motorola, some of the specific button functions have secondary functions built into them. For example, RSSI/SITE will display site and RSSI info but if you long press it it will go into SITE SEARCH function.
Salmon_Glove
What I'd like to be able to accomplish is to set the keypad lock where it requires depressing two keys in order to unlock the radio (I'm not picky about which ones). The second thing I'd like to accomplish is being able to lock the side keys but still have access to the red top button which I have set as the scan button. From what I can see, It appears that I have to choose whether I want both the side and top buttons locked or unlocked, the top red button can't be left unlocked while locking the side buttons.
Project25_MASTR
Texas
That's going to be a very one off configuration. Typically that red button would be fore emergency and by definition when programmed for emergency is the only button that could override the keypad lock. That being said, keypad lock on/off is typically always a long press on Motorola/EFJ/Harris/BK.
