DVRS overview
DVRS OVERVIEW:
Each vehicle is equipped with a Digital Vehicle Repeater System (DVRS) – an even more intelligent version of the old mobile/vehicle “pack rat” repeater. The DVRS relays conversations between the VHF trunked mobile radio and the portable 700/800 MHz radio. The XTS 5000 portable radios operate on the 700/800 MHz bands only. The XTS 5000s depend entirely on the DVRS to connect them with the trunked network. Mobile radios are VHF only, and are unable to access the 700/800 MHz channels which are exclusively programmed in the portable radio. The DVRS, however, allows the portable radio to access the VHF channels in the mobile radio, but not vise versa. The portable radio may be used to change talkgroups within a single zone on the mobile radio, but it cannot change between zones. At a incident scene, units share the one DVRS that arrived and when online first. Regardless of what talkgroup the multiple users are on, all portable radios sharing the same DVRS will hear the same radio traffic. Using a discrete 700 MHz frequency, portable radio users can speak directly with each other on a simplex freq or use the DVRS in the “local” mode as a standalone repeater.
This next part can really apply to other systems besides STARS (you need to read between the lines.) So as the other poster said, check the FCC frequency assignment scheme for assignment for state licensees @12.5 khz. Spacing in 700 MHz. You end up with a lot of nice base/mob freq pairs. Then take each pair and assign a number 1 through X. (In the case of STARS its 48 Channels.)
Each numbered channel then gets assigned to each zone in a radio (do this for every agency on the system) the zone can be trunked or conventional (or even mixed) and this acts as the connection to what ever channel your mobile radio is set on – or it can be used as a simplex channel to others using the same zone (in the same division) on the mobile. It can also be in a ‘standalone repeater mode’ if the channel on the portable and the channel on the mobile radio are both set to the same VRS channel. For example if the portable is on VRS 1 and the mobile is on trunk TG 1 the portable will talk through to the TG 1 – whereas if the portable is set on VRS 1 and the mobile is set to VRS 1 as its channel – then it creates a mobile repeater using that VRS channel pair. The standalone mode is selected via the mobile radio control head in the menu by pressing the “VRS” button repeatedly until your channel changes from one in that zone to the VRS channel.
If you're the system planner, you probably save one pair of freqs exclusively as statewide simplex 700MHz talk around type channel using this particular pair not connected to the mobile radio (or trunked system.) For example on the portable radio if you press and hold a certain button for 3 seconds it will take you to that “direct” channel so you can talk to anyone else on the portable simplex to simplex. This is not to be confused with “standalone repeater mode” mentioned above. This "direct" channel mode uses the one half of said channel pair and the other half could be reserved from some other use or not used at all.
The photo attached shows XTL 5000’s control head display showing: VR (Vehicular Repeater) which in this case is OFF but it is set to VR CH-42-A (765.71875). Zone 16 (Z16) is one of the two zones for the current conventional (CV) VSP channels.
The DVRS is turned on and off manually except during a bail out emergency where it is activated by a door pin switch.
(Much of this info can be found in the CHM newsletter from Jan 2010, including this photo by someone named Darrell Rayfield).
