vx 354 2 tone help
dmbasb
I'm having a problem with the VX-354 VHF radios and 2 tone signaling. I'm trig to set up two channels with 2 tone paging and Plectron tones. The first is on 154.190 with a ccts of 167.9 and a tone set of 910 and 1985. The second is on 155.160 with a ccts of 192.8 and a tone set of 910 and 1130. The dispatch console sends out the tones at .75 and 2nd at .25. tone set. When the tones are sent out the led will blink green and the receive bars will show reception. The radio will not un-mute and go to monitor. The display does not show call after the tones are sent out. I have tried several things but nothing works
