VX-4000 Group Scan
pkrawetz
Georgia
I know this can be done but it's not obvious in the programming software. How can I program function key to perform group scan?
Thanks in advance for any info you can provide.
RodStrong
West
I have never had that particular model, but on some other Vertex models, if you push the scan button, you will get one type of scan, such as bank scan, and if you do a long push on the button, it will do a group scan (if I remember correctly).
Not sure if that makes sense, but try a short press and a long press of your scan button, and see if that makes any difference. Good luck.
n3obl
ØAES-1024
PA
If you dont have the group in the scan list you need to add it by holding down the zone up/down key til it says scan stop.
You add/delete zones like channels. If no zones are selected it will just go OFF / scan /OFF instead of off / scan / grp scan.
Frank
pkrawetz
Georgia
Rob, I think you have the answer. Once I get the programming cable I will assign SCAN to one of the functions keys and try it. Thanks.
n3obl
ØAES-1024
PA
I use one as base station. Also i hex edited the codeplug to allow ham use in 2mtrs,
Frank
