VX400 ARTS feature Programming problem
Clermont, FL
#1
I just got 4 VX400 UHF radios and I have the CE24 software for them, but I have no option to turn on the ARTS (Auto Range Transpond System) feature on this radios anywhere.
#2
In the CE24 software the ARTS option is not automatically shown. You will need to read your radio, then select the VIEW menu option, drop to ITEM and then select the ARTS option at the bottom. This should add the ARTS option to each channel, you can then set it per channel I believe from there.
Clermont, FL
#3
Thanks for the info, It works now
