VX4600 firmware update
rparker87
Mystic, CT
I searched and searched with no luck. My vx4600 has firmware 1.19
I tried to upgrade it to the newer ones on vertex group with no luck. The radio keeps power cycling and I get an error: 02 communication error.
I changed the rate of the com port to 1200 with no luck and am using the appropriate cable
msrettinger
Oelwein, Iowa
I had the same problem. I have a generic cable that I bought off Ebay. It works fine to program the radio, but I could not do the firmware update. I had to take it to a dealer. He said it has to do with the cable. I don't remember exactly why, but he had no problems updating the firmware.
k7plt
Yes, you need to use the CT-104A cable and FIF12A cable to accomplish this task. USB adapters using the Prolific 2303 USB chips are spotty at best, and aquiring a USB driver to work "reliably" with this chip is a daunting task to say the least.
Hope that helps!
